omc repower questions
cmorr176
i now have a 73 grady with a merc inline 6 mated to an omc stringer electric shift.can i put in a 4.3 V-6 ?will it bolt up and will the outdrive handle it? i assume i will have to modify the motor mounts. any other issues i need to be aware of? thanks
Mystic Dragon
Re: omc repower questions
cmorr,
I am by far an expert at these things but I would think that, before this change, it would would be worth looking at the exhaust issues.
I replaced an OMC 3.0 with a Merc 2.5 which are supposed to be identical blocks and I had to change the bellhousing, coupler, cable harness and now the manifold and riser because of the mismatch with the OMC exhaust pipe. And it is a used motor so I still haven't an idea of the shape its in.
Just something to think about. These parts are expensive so that is why I mention it. I just dumped $480.00 into it after shelling out $1200 for a motor they said was supposed to "just drop in and go".
Good luck with it either way.
B.O.A.T. (Break Out Another Thousand) LOL
Take care.
I Think that,... That particular Swap would be a Waste of Time,+ Money,.......
As well as about Impossible to accomplish,.......
The Fitment Issues would be EVERYTHING but the Bellhousing Bolt Pattern........
You'd do Better, just Junking the Stringer Drive Completely,+ swapping in a 4.3l Volvo, or Mercruiser.......
cmorr176
what would be the best way to seal transom hole to allow mercruiser outrive conversion? plywood and glass,? epoxy ?
Ayuh,....... You've got it......
