OMC outdrive damage: was I shafted? (email & response from Stuart Hastings)
lakelivin
This is an 'addendum' from the post linked below. Moved here 'cause the original post was getting too long.<br /><br /> http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic&f=24&t=008398#000032 <br /><br />My email & response from Stuart Hastings. (My original email noted by the '>' mark.<br /><br />On Sat, Aug 28, 2004 at 02:52:07PM -0400, LakeLivin wrote:<br /><br />> Hi Stuart, I got this email address from one of your web sites, hope<br />> you have the time and patience to hear me out. Sorry about<br />> contacting you directly, but in a way it's your own fault for the<br />> masterful job you've done in researcing & documenting the OMC Cobra<br />> issue, lol.<br /><br />Well, I intentionally left my email address somewhere in the web<br />pages, so yes, I get emails from time to time. Many come from outside<br />the U.S...<br /><br />> I apologize in advance for the length of this, but want to make sure<br />> I portray everything as completely and objectively as possible. I'm<br />> not looking for any specific technical advice, just your overall<br />> impression based on the facts.<br /><br />Not a problem. You write well.<br /><br />> I have a 1989 Seaswirl with a 4.3L OMC Cobra. In June 2003 I took it<br />> to the only repair shop on our lake (owned by a neighbor) to have<br />> the engine tuned and the outdrive serviced. I know OMCs are<br />> different animals from Mercs so I asked the owner if they had OMC<br />> experience and he said no problem. My boat had only 416 original<br />> hours on it at the time. After the boat was done I drove it home<br />> approx. 4 or 5 miles.<br /><br />> The next day I drove it approx. 1 mile to a friend's house. When I<br />> left to return home the outdrive started screaming (an extremely<br />> loud whining noise, kind of like a jet airplane). It was 11:30 pm so<br />> I limped home and called the repair shop the next day to report what<br />> had happened.<br /><br />> The mechanic and the shop manager came out, listened to the drive,<br />> and checked the gear oil. It didn't register on the fill stick so<br />> they checked the drain plug to see if there was any oil in the unit<br />> (there was). They added a full tube (10 oz) of gear oil they had<br />> brought with them, along with what was left of a partial tube<br />> (approx 1/2 to 3/4 full) I had in the boat house. When I checked the<br />> level the next day it was still low so I got some more oil and added<br />> maybe an additional 6-8 oz. All in all, it required a total of an<br />> additional 20-25 oz. or so to bring it up to full capacity (2<br />> quarts).<br /><br />> When the shop manager and mechanic checked the low fluid level they<br />> discussed whether the unit had been filled from the bottom (drain<br />> plug) or from the top of the drive (where the measuring stick<br />> is). The mechanic stated that he had refilled the oil from the<br />> bottom drain plug. Neither was aware that OMC Cobra outdrives have a<br />> specific fill plug several inches above the drain plug.<br /><br />> When I ran the boat after refilling the outdrive oil I noticed a<br />> whining noise coming from the outdrive that hadn't been there<br />> before. This was much more subdued than when it first happened but<br />> still definitely noticeable to me. I called the shop owner to<br />> mention my concern and he came out to listen to the drive. He said<br />> he didn't think there was anything abnormal about the sound (but he<br />> hadn't heard the drive before the incident so he really didn't have<br />> a specific baseline for comparison, either).<br /><br />> A neighbor who was very familiar with the boat did note the change<br />> in sound the first time he rode in it after this happened. He hadn't<br />> heard about the incident with the low outdrive gear oil but<br />> independently commented on the change in the boats sound. He thought<br />> the boat sounded 'kind of turbocharged' after the tune up, but when<br />> I shifted the boat in & out of gear it was clear that the extra<br />> noise he noted was coming from the outdrive.<br /><br />> Shifting became progressively harder as I ran the boat sparingly for<br />> the rest of the summer (approx. 17 hours).<br /><br />> Before launching the boat this spring I was still concerned about<br />> the outdrive so I took it to a shop with a reputation for OMC<br />> expertise (about an hour and a half away) to have them pull &<br />> service the drive. The manager called me back and told me that the<br />> gears and bearings were shot and would need to be replaced. I asked<br />> him if the damage was consistent with what might happen if the drive<br />> had been run significantly low on oil, and he replied that it was<br />> (or that someone had hit something hard with the prop, which I know<br />> didn't happen).<br /><br />> Reasonably certain the damage had been caused by the local shop who<br />> had left the oil level low, I explained the situation to the owner<br />> and made the following suggestion: that I would pay for parts (gears<br />> & bearings) at their cost if they would do the labor for free. They<br />> told me to bring the boat back and I did.<br /><br />You are very generous.<br /><br />> Over two months later they told me the boat was finally done and<br />> sent me an invoice that was $150 more than the other place would<br />> have fixed it for. Turns out instead of replacing the gears &<br />> bearings, they put in a completely rebuilt upper drive plus they<br />> charged me for half the labor (they've since agreed to cut out labor<br />> completely, but the rebuilt outdrive is still more than twice the<br />> cost of new gears/ bearings).<br /><br />> In the meantime, I found your site about OMC Cobra outdrives and the<br />> tips you received from the OMC service tech people, specifically:<br /><br />> ? When filling the Cobra with gear lube, use the middle fill plug,<br />> as shown in the Owners' Manual. Do not fill through the (bottom)<br />> drain plug! If you fill from the wrong port, you will probably trap<br />> a big bubble of air inside the vertical drive, and that bubble will<br />> eventually rise to the top. When it does, the upper gearcase gears<br />> will run dry, and self-destruct. As they say in the computer biz,<br />> "RTFM."<br /><br />> Now instead of being reasonably sure the first shop caused the<br />> damage I'm about as close to 100% sure as you can be. I'm furious<br />> that my gesture to 'split' the cost to fix the boat was so badly<br />> manipulated. The shop owner claims that the damage wasn't due to the<br />> low gear oil, but that something else 'just happened' to go wrong<br />> with the drive exactly at the same time they left the gear oil<br />> low. He sited the age of the boat (15 years) ignoring the fact that<br />> it only had 415 original hours on it. The shop owner also sited the<br />> following reasons he thought the damage wasn't due to the low gear<br />> oil:<br /><br />> 1. He said the gears weren't 'blackened' and that there was no burnt<br />> smell in the outdrive (of course the gear oil had been drained by<br />>the other shop a couple of months before the original shop ever opened<br />>it up).<br /><br />So what? Running the gears and bearings without oil is abuse. OMC<br />gears might be made of a different alloy that doesn't fail the same<br />way as the MerCruisers he's evidently familiar with. If these folks<br />are not familiar with Cobras, how would they know what a typical gear<br />failure looks like?<br /><br />> 2. He said the timing wasn't consistent for this type of damage (I <br />>drove it 5 miles, let it sit over night, and drove it another mile<br />>before the outdrive started screaming).<br /><br />Has this person ever worked on another Cobra with this failure?<br /><br />> 3. He said the boat wasn't driven long enough for the damage to have<br />> resulted from low gear oil.<br /><br />I'll bet that Bombardier/OMC would disagree with this.<br /><br />Question for the shop: How long would a slack-filled MerCruiser last<br />in similar conditions?<br /><br />> 4. No gear teeth were completely missing.<br /><br />I don't think this is relevant.<br /><br />> They didn't show me any of the bearings but did show me the gears<br />> and claimed that because they weren't 'blackened' the damage<br />> couldn't have been due to the low level of gear oil they left in the<br />> drive. I saw that the gears were torn up but not 'black'. However<br />> the lighting wasn't very good (it was indoors and the drive was in a<br />> box) and based on their terminology I was looking for true black. I<br />> wouldn't have necessarily noted if they were 'blued' vs just dark<br />> grey. I do know they weren't a shiny metalic. So I honestly can't<br />> say if the gears themselves were 'blued' or not and the old drive<br />> has since been sent to the rebuilder.<br /><br />I respectfully suggest that the color of the gears is moot. The oil<br />was drastically too low, and the gears and bearings failed. This<br />sequence of events won't surprise anybody, except perhaps the folks<br />that slack-filled your sterndrive.<br /><br />You could ask Bombardier/OMC, but I'll predict their answer: "Running<br />the drive while low on oil is abuse, and voids all warranties." The<br />gears might turn blue, splay, break, or all or none of the above; all<br />bets are off when it's run dry.<br /><br />Your shop seems to be saying "it didn't fail exactly the way we<br />expected, therefore this couldn't be due to low oil." I'll bet any<br />technician with OMC expertise would be willing to refute this in<br />court.<br /><br />> I posted to what seems like a great forum at iboats .com (my<br />> specific post is linked below) and there is almost universal<br />> consensus that the damage was caused due to invcorrect filling of<br />> the gearcase. One mechanic (P.V.) listed how several variables<br />> would effect the timing until damage might occur from low gear oil.<br />> Another (seahorse) indicated that he has seen several cases where<br />> gears were ruined from low oil but without actual 'bluing' of the<br />> gears themselves.<br /><br />> http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=24;t=008398 <br /><br />> The original shop owner still claims that the damage couldn't have<br />> been due to their mistake because of the timing and the symptoms of<br />> the gear failure.<br /><br />I respectfully disagree.<br /><br />> Even though I'm certain the shop trashed my gearset, I've offered to<br />> 'split' the cost to get it repaired. The owner has reduced his<br />> charges somewhat, but still wants over $1600 to fix the damage that<br />> I thnk they caused but that he thnks was unrelated to them returing<br />> the boat with low gear oil. The only positive thing at this point<br />> is that he did state that he's open to 'expert' input about the<br />> issue. I showed him the stuff you've put online and it's clear he<br />> recognizes and respects your expertise with respect to OMC Cobras.<br />> He indicated that he would be willing to listen to and consider your<br />> opinion about the incident.<br /><br />> Recognizing that you've not seen the drive and are obviously limited<br />> to the information described in this email I ask for the favour of<br />> your opinion: Given the circumstances I've described above (and<br />> especially considering the owners reasons he thinks the damage was<br />> unrelated to low gear oil) what do you think the odds are that my<br />> gears were damaged as a result of the shop's incorrectly filing the<br />> outdrive and leaving the gear oil low vs. something unrelated that<br />> just happened to go wrong at that exact point in time (it is a 15<br />> year old boat but with only 415 original hours on it)?<br /><br />My opinion? First, I'll aver that I am NOT an expert in anything.<br />I'm a computer guy with a shadetree-mechanic habit. Furthermore,<br />all of the sage advice on the website came from OMC; all I did<br />was put some OMC Service Bulletins onto the web.<br /><br />However, your sterndrive disaster passes the "duck test." It waddles,<br />it swims, it flies, it quacks: it's a duck. Your documentation is<br />thorough and convincing.<br /><br />For what it's worth (basically "moral support"), I agree with your<br />diagnosis.<br /><br />In my opinion, that shop ruined your sterndrive by<br />slack-filling it with oil, and they should fix it<br />at no cost to you.<br /><br />> I'm really not trying to put you in the difficult position of<br />> getting into the middle of this, and suspect you've received so many<br />> requests looking for additional technical advice beyond what you've<br />> posted online that there's a good chance you'll delete this before<br />> even reading it. But I'm hoping that the shop owner and I can draw<br />> on enough independent expertise to help us reach an agreement that<br />> keeps us out of small claims court, and unfortunately he recognizes<br />> you as the guru (and obviously as being independent) .<br /><br />I agree that I'm independent, but I'm am uncomfortable with the<br />"expert" label.<br /><br />> Thanks for any input you might provide.<br /><br />You're very welcome. I hope you can get that shop to make this right,<br />financially. Of course, you've already lost a great deal of time and<br />effort researching and documenting this... you'll never get back<br />your time. :-(<br /><br />> LakeLivin<br /><br />> p.s. congratulations on the documentation you put together on the<br />> Cobra outdrive. As someone who used to be responsible for compiling<br />> complex specifications for technical work in pharmaceutical<br />> development I probably appreciate it more than many. I'm of the<br />> opinion that done right, specification/ instruction/ documention can<br />> almost approach an art form!<br /><br />Well, most of it was cribbed from OMC itself. If you don't have a<br />genuine OMC Shop Manual for your drive, I respectfully suggest you buy<br />one. Ask Bombardier, or look on Ebay (search for "omc cobra"). I<br />also own copies of the Seloc and Clymer manuals for the Cobra, and I'm<br />unimpressed with both.<br /><br />I'm very sorry for your trouble. Regardless of the evident technical<br />merit of the Cobra, if nobody can be trusted to fix them, they become<br />worthless as sterndrives. :-(<br /><br />I wish you better luck with your Cobra,<br /><br />stuart hastings
DHPMARINE
Re: OMC outdrive damage: was I shafted? (email & response from Stuart Hastin
No you were not shafted.I'll reply further on your other post.<br /><br />DHP
walleyehed
I've been following/reading as I could on this, and Seahorse hit on something that caught my attention...."The gears actually flaring to the point they won't come apart". This, (to me) explains why an upper gearcase was installed insted of just gears and bearings.<br />Our practice at Cedar Mills is to save all parts for customer, and/or warranty. It doesn't sound to me as though you got a real good look at "all" of the pieces...we make it a habit to show the customer EXACTLY what has happened, and include ALL parts replaced.<br />Am I correct in assuming you don't have possesion of the parts replaced???
lakelivin
walleyehed,<br /><br />No, neither of us has possession of any of the parts. When they put in the rebuilt upper drive they sent the old core back to the place they got the rebuilt drive.<br /><br />The ONLY thing I got a quick look at were the gears (still in the upper unit), which were clearly torn up. BUT, the OMC certified shop that told me about the damage got a detailed look at the drive and the damage. They said I'd need new gears & bearings (not a complete upper drive). They also identified the damage as being consistent with running low on gear oil.<br /><br />Keep in mind that the drive hadn't reached the point of complete failure (although that wouldn't have taken much longer had I kept on driving it according to the OMC shop).<br /><br />Actually, the shop owner that slack filled the drive in the first place told me why they put in a rebuilt upper unit. He said because of the complexity of replacing the gears (shimming, etc.) they wouldn't have been able to offer any warranty on the repair. Looking back on it, I think it was because of either:<br /><br />1) the increased amount of labor replacing the gears/ bearings would have entailed vs. just bolting on a rebuilt upper unit.<br /><br />2) their mechanic didn't have the OMC expertise to do that job.<br /><br />or some combination thereof.
DHPMARINE
Rebuilding a Cobra upper drive is a piece of cake with the correct OMC tools.But because of the time to press things apart,and press back togeather I can understand replacement as a less costly method.<br /><br />You told me earlier that the unit ran 17 hours,and I doubted it until you added after the oil was topped up.Too bad you didn't run another hour or two,and seize it.<br /><br />Is the OMC shop willing to testify?This has only come up a few times where I am,and while we don't love the 'other guy' we have to live with him,and sometimes swap parts/info.<br /><br />DHP
DHPMARINE
One thing I keep forgetting to check,and maybe pertinent ........that means look for yourself.. ..Grin<br /><br />Get a 1986 OMC Cobra service manual,and see how they say to fill the drive.I think they say from the bottom,till it reaches the dip stick at the top of the drive.<br /><br />Later they decided fill from the middle to eliminate air pockets.That might leave it a few ounces down.<br /><br />I think you said your outdrive was down 24 or 25 ounces after the service,and when they topped it off.<br /><br />I don't have to put money on it.BUT was your drive filled from the bottom to the middle plug?<br /><br />DHP
Lou C
Don't know what the 1986 manual said but for sure both the OMC shop manual and the owners operating manual for my 1988 says to fill from the middle plug, and it lists the capacities so you know how much should be put in there. Instructions are clear enough that if they did not do it right, they must have never looked at an OMC manual :( <br />Kinda like having a Chrysler auto trans, different than most others, you check the level with it idling in neutral not park, and you have to use the ChryCo auto trans fluid (ATF+3/4 depending on the year), not like Ford and GM.
Don S
Hey guys, if you read his other post on this subject all these questions were answered there. Here is a link to the other post so you don't have to look for it. It starts off Aug 2004 and goes to present time.<br /><br />Link to other post
DHPMARINE
Don S , <br />just an after thought I had to this new post.I take winters off (sort of) and was in the shop today and didn't remember to grab the 1986 manual and look.<br /><br />Lou C.we don't measure the oil we put in,we just fill it until it's full.I use a 3 gallon pressurized tank.<br /><br />DHP
lakelivin
DHP,<br /><br />This appears so clear I was wondering why you had doubts as to what caused the damage. The fact that you mistakenly thought I ran the boat 17 hours low on oil before bringing it back to full level explains it. As you're now aware, it was run low for prolly less than 30 minutes total (seperated by 2 periods of 'rest') before the drive started screaming. Not run again till they came out & 'topped off' the oil level (if you can call 26 oz short out of 64 oz 'topping off'). After topping off, drive had a whine that wasn't there before.<br /><br />Yeah, too bad it didn't seize up immediately. If I had driven it more than a few minutes after it started screaming I'm sure it wouldn't have have been a matter of hours, but a matter of minutes till it seized. But then it would have prolly trashed the casing as well. The OMC shop told me that it wouldn't have been too much longer until that would have happened after the refill and 17 hours I put on it anyways.<br /><br />As per others recommendations (thanks) I've got the 1989 OEM service manual. It clearly shows how to fill the drive (from the middle 'fill' plug) and specifically states that "running drive with improper oil level will result in immediate internal damage". <br /><br />The OMC shop owner can't be here in person 'cause he's about 1.5 hours away, but he did mail me a notarized statement with his opinion that the damage was consistent with running the drive with a low oil level. Hopefully that, combined with the fact that it started screaming the day after I got it back, combined with the mechanics admission that he filled it incorrectly, will suffice.<br /><br />Now that I've learned so much I'm pretty sure the original shop not only doesn't have experience in rebuilding an upper drive, but that they don't have specialized OMC tools, either. Of course they didn't tell me that when they agreed to repair the gears & bearings...<br /><br />Lou C:<br /><br />You're right, and the shame of it is I specifically asked the owner before I brought it in for service if they were familiar with Cobras! He told me 'no problem'; yeah, right.<br /><br /><br />Don's right, for any additional posts not specifically related to the info from Stuart Hastings I posted here to save space in the original post (or specific to the few follow ups that were posted here), probably best that we take this back to the original post (Don linked it above).
KaGee
Gee boss, always did want to werk on one of dem dar Cobras!<br /><br />Seriously Lake, it's a crying shame. After seeing some of the pieces of work that are employed by some of the boat yards around here, makes ya wonder how they stay in business.
DHPMARINE
LakeLiven, I was amazed until you explained the 17 hours was after the refill.I am also amazed the drive went 30 minutes that low on oil.And went 17 hours before the teardown.(after the top up)You were lucky<br /><br />I finally figured what has been bothering me,and it should be no concern of anyone here.Just another point of interest... maybe.....what do you think ?<br /><br />Drive capacity 60 to 64 ounces..<br /><br />Ounces added to drive when found low 26 ounces.<br /><br /> I think your out drive was filed from the bottom hole to the middle hole,like any outboard.<br /><br />Outbaord holds 32 to 34 0unces.<br /><br />DHP
lakelivin
KaGee,<br /><br />Thanks for the support. <br /><br />I know your question about how some shops stay in business was rhetorical, but I've actually got some credible theories for this one. For one, they're the only shop ON the lake (165 miles of shoreline, about half natural, half with houses, most of which have boathouses and 1 or more boats (some people have an i/o or v-drive for play, a pontoon for different play, a bass boat, and 1 or more jetskis). Then there's me with my '89 17ft Seaswirl, lol. <br /><br />There's a shop in town that will service your boat on the lake, but only if you bought it from them (mostly Cobalts & pontoons). I'm sure people with newer Malibu's, etc. drive em to where they bought 'em for service (about an hour away). These guys may even be ok with mercruisers, I don't really know. <br /><br />BUT, I've heard through the grapevine they're looking to sell the business, so the answer to your question may well be that they can't.<br /><br />The one positive with all this is that it led me to discover the iBoats forums. Can't tell you how much I've learned on here, probably most of which I'll never use, but I'm sure some of which will prove invaluable. I'm almost addicted to reading a couple of the tech sections. I even find stuff like the 'oil wars' informative and amusing, lol.
lakelivin
DHP,<br /><br />Actually, probably wasn't even 30 mins. Maybe 15 mins when I picked it up, 5 minutes the next night, and then pow. Someone on the main thread talked about the variables that would effect time to failure, like some oil still coating insides even after draining, combination of drive trim, air, & water temps when operating, splashing of whatever oil was there, time for air bubble to work to top, etc.<br /><br />As far as what I think? They stated that they filled from drain plug. Could be that they filled from the drain plug just to the fill plug. Some have talked about doing it that way as step 1 of another way to fill a cobra (although not documented by OMC). They could have forgot step 2, which is to then plug the fill hole and continue to the top of the drive. <br /><br />But I'm pretty sure they didn't know enough about Cobras to try an alternative method and forget the second part of it. So if they filled just to the fill plug, they were treating it like it was an outboard, which is SO big a screwup I kind of doubt that's what happened. Plus, I'd guess that if they did that almost NO oil would have made it to the upper unit and I wouldn't have even made it the 15 minutes back from the marina.<br /><br />They were so short on the oil I think it was a combination of whatever air bubble was formed from filling from the drain hole and whatever air bubble is formed from filling too quickly (the OEM service manual mentioned that filling too quickly can also lead to air bubbles, even when filling from the corredct plug).<br /><br />As an experiment, maybe next time I change the outdrive oil I'll fill from the drain plug and see how short that leaves me. Obviously I wouldn't operate the drive till I work out the air pockets and get the full 64 oz in there.<br /><br />Anyone know if I'd have trouble working out the air pockets by repeatedly raising & lowering the drive?
Lou C
I have filled it the book way for the last 3 years without problems. What I do is fill it from the middle, slowly, with the dipstick resting in the hole in the top cover (not screwed it, this helps purge air). Then re-check level, if ok I replace the dipstick, screw it in, and remove the pump, replace fill screw. I then leave it overnight and re-check at the dipstick. I have never (so far) had any drop in the level doing it this way. Before I put the boat in the water, I will check it before starting, then run the boat on the muffs, shut it off and re-check. And it is always at the right level. The only time it has not been has been when I had a seal leak and the level was abnormally high, because of water intrusion. I had the seals done over this winter, and my OMC guy will reinstall the drive in the spring.
rodbolt
hello<br />next time ya change the drive oil fill it from the bottom. you will find that the hole where the drive shft that connects the driven gear in the upper to the pinion in the lower will pass oil just fine. that case is a lighty modifed V6 gear case. instead of haveing a drive shaft bearing housing with an oil seal at the topof the lower. it has an adapter that seals the lower to the upper with 3 big orings. there is about an 1 1/2 inch passage between the upper and lower. I think the scenario about filling from the bottom till it came out the middle then they forgot to finnish filling it is the most likely. I saw it once. I dont know why OMC filled the way they did but in anycase your not going to have an air bubble that will displace 26 ounces. I just think they failed to add enough oil.kinda like for years chevolet said you could not change the timing cover on a smallblock chevy without removing the pan. I did it for 15 years or so without removing the pan. it does however rquire the inside corners tobe trimmed with a 45* angle to reinstall it. ment we got paid all the hours on commision and did not have to fight the oil pan.I was working on stringer drives when the cobra came out. we did more cobra work in the late 80's and early ninties than most. the commercial guys loved them. the only real weak spot after about 1990 was the lower gimbalswivel pin. but OMC said there was no problem. there was and is. its very easy to correct but most techs never did.
lakelivin
rod & DHP, <br /><br />As far as my court case this is all pretty much moot, cause the bottom line is that I got the boat back low on gear oil, however they managed to do it. I'll probably never know the exact details for sure.<br /><br />But it is interesting to speculate. One other thought that hit me; what if they drained from the fill plug & just forgot to refill at all? Any chance that would somehow leave the appprox. 38 oz. that was in the drive when it came back?
rodbolt
yep<br /> that is about the capacity of the lower unit. and I have seen that before as well. a guy that worked for a dealership I was working forin Norfolk, I talled him Turbo. he was one of them people that went flat out and always wanted to go faster. on this day he drained 4 lowers at the same time and was changing oil in between running about doing other stuff. somehow one of the boats did not get refilled. about the time the customer called about a noise in his case I noticed a set of drain and fill plugs on the cart.<br /> turbo was a likable guy but he could tear up more on monday than I could fix the rest of the week. I kept telling the marina owner if you pay peanuts you get monkeys. bottom line is the drive was not filled to proper capacity. how it was not is kinda moot.
