Re: OMC or Merc Outdrive-which is best?
If the drives are really 1994s, they are probably the joint venture ones, and those can be serviced at a Volvo shop. However, somtimes a 94 boat will have a 93 engine/drive, so you have to check the ID#s (on the thermostat housing, transom plate, and drive housing). The 94 and newer ones look different than the 86-93 ones, there is a raised portion on the top of upper housing (original Cobra was flat across the top) and they do not have the water pump access panel at the rear of the upper housing (impeller is engine mounted on the newer ones). So see what you have there first.<br />Now of course if it is an OMC unit and you got good service before just stick with them.
