OMC late model 15 hp carb adjust
thatone123
Banned
This is the made in Mexico Plastic topped models. Never had any big problems with these but do now. Engine very hard to start. Can get it to run for 20 seconds but is running real rich. Cleaning the carb for the second time. There is the idle speed adjust screw on the side top which has been (now) turned out 4 1/2 turns which is the starting point, I understand. This idle circuit seems connected to the top front larger screw. Does this larger screw have anything to do with the idle or should it be turned completely in or adjusted also?
thatone123
Banned
J15REUC Parts schematic lists the screw as a plug and the other screw as a slow speed needle. I guess this big plug screw should be screwed in and closed. Interesting that there is that square cut out next to the hole like the old OMC's have for that usually for that thick red plastic gasket like thing on the old idle speed adjusters and rich/lean screws. Carb is clean. good spark, no leaks in hose, all the usual culprits. IT may be the float is not adjusted right as I had to bend the arm to get it to sit straight? Don't think so though. Any other ideas?
oldboat1
http://ww2.iboats.com/Carburetor/dm/...iew_id.1533893
Need to be sure you are using the right gasket under the plastic top (#11) -- correct configuration. Carb kits come with three different ones for different models.
After soaking, use carb spray and nozzle to clear all passages. Note float orientation -- shouldn't require much adjustment, if any, to lay flat and level. I leave it level. Some guys lower the outer end a little (i.e., raise it when the carb top is inverted).
If the carb is squared away, your issue may be the fuel pump (may need new diaphragm). Squeeze the primer bulb when it wants to stall, and see if you can keep it running that way -- indicates a fuel pump issue.
thatone123
Banned
Carb is clean, right gasket...runs better now, but rough and hard to start. Feel like I am almost there but... I will try the 3 turns out. Pretty sure it is the carb (per the improvement) or carbon deposits in the cylinders. Am trying OMC engine tuner as we speak. -so to speak!
thatone123
Banned
Got it!!! Probably part silly mistakes. That 4 1/2 turns was way too much and I did a lot of trail and error. When I made it real lean it runs good now. Probably did not need carb cleaning and etc. TNK Kind of miss the ol' 7o's /80's models can tune those to perfection. (usually) anyway.
