OMC KIng cobra change hydraulic manifold
crankman1
Electrolysis has dissolved my hydraulic manifold on the out drive and was hoping someone has change one before and might give me some handy tips when i change mind.
Lou C
Post a pic of which King Cobra you have, there are different styles. One is basically the same as the standard Cobra, the other is much larger, heavier duty and totally different than the standard dog clutch Cobras. On the standard models, that is a pretty big job, involving removing the drive and pivot housing. If you have never done this before and this was a salt water boat you might want a professional mechanic to do this job.
jerryjerry05
Get a factory manual.
He says he's from Ontario, Canada.
So if he's never had his boat in salt water I wonder why it ate the manifold???
Sounds like a short in the electrical system??
Always post the year, model.
You can add a signature with any pertinent information.
Like Lou said not an easy job.
New they're $350 Used on e-bay
