OMC Johnson lower unit will it fit?
Foul Play
I have a 1990 OMC seadrive 200 hp. My lower unit went out and I found a 1993 225 Johnson. Does anyone know if I can use this part? Or if more info needed let me know Ill see what I can do.
Faztbullet
Re: OMC Johnson lower unit will it fit?
As a direct bolt on and go answer is no... the unit will work if you do a couple of slight mod's. If you have the 25" model you should have the 2 piece driveshaft which you can have removed and installed in the 1993 unit. It takes a driveshaft removal tool and about 20 minutes to swap both.
Foul Play
Both shafts are one piece what other mods do you think i need to do?
