Motor is 1986 OMC 4.3l.
In the 7 years I've had this boat it has always run like a champ. Only one other time was it running rough and a change of plugs fixed that. Last time out boat was running really rough. Figured it was time for a bit of a tune up. Replaced the plugs, wires, points, rotor, condensor. I ordered the tune up kit from iboats for the points. When finished boat wouldn't start. Did everything but turnover. After trying a few things that didn't work, I decided to put the old points back in. (at least 7 years old!) Engine fired right up. I didn't realize that wrong points would make a difference between starting and not starting. After seeing the old points I really want to replace them but not sure where to go.
Thoughts?
Thoughts?
