There are several posts from a number of years ago concerning the OMC electrohydraulic shift mechanism, and I certainly have benefited from lurking here, getting answers that I didn't have to ask, but I see no photos of the shift shaft. I've been researching all day, and I'm hoping someone is still around who has experience with this.
I just acquired a 1968 Evinrude 55 with the lower unit detached and shift shaft disassembled, and looking at it I don't see how it will make any controlling movement to the pump. Mine has a two piece shaft, the out shaft has a sort of cap on it, and the inner shaft is simply straight and sticks out of the outer shaft. I see a hinged metal flap with a hole in the middle, at the oil pump where the shaft(s) should reach, but there doesn't seem to be anything on the shafts that would catch that to pull or move it.
The Clymer manual seems to show shafts like mine, but I see the online diagram at marineengines.com show a couple springs under the solenoids with a barrel at the end, and a shift rod assembly offered on Ebay for my motor, with the proper part number, that's much different, and like the one offered. The guy I bought the motor from says it was his dads and it did shift, and he's quite sure everything is there that he took out. I've finally decided to clean out the lower unit and assemble it with the parts that are there, hoping I don't have to take it back off for non-function. Anyone have some insight on the different designs of the shift shaft and how it actually works at the pump? Were there changes made during the model year?
1972 johnson 65 hydro-electric shift Page: 1 - iboats Boating Forums | 452104
72 125HP Evinrude Hydroelectric shift, grinding noise shifting into fwd or rev Page: 1 - iboats Boating Forums | 10164845
1969 85 hp evinrude hydro electric issues Page: 1 - iboats Boating Forums | 305327
hydroelectric shift solenoids Page: 1 - iboats Boating Forums | 10466585
http://forums.iboats.com/forum/engi...hp-evinrude-hydro-electric-issues?view=thread
