caravellelegend
- Jun 11, 2011
- 5
Hello, This will be my first post on a boating forum so ill try to be as specifcic as i can, Ive done hours of searching and havent gotten answers to my questions. And id love to be able to get information from a few OMC pro's that can maybe save me alot of work an money... I had to remove my cobra drive from my boat to replace the leaking bellows, that all went well but i used a old cheesy clymer manual that didn't state how precice the transome cable and bellcrack had to be setup before re installing the drive.
However, i set the cable legnth and then set the bell crank at 90* "as per the clymer manual" then reinstalled the drive. then finished installing the new control box shift cable, but the problem im having is it shifts from nuetral to foward really smoothly but when i go to reverse it dosent throw the cable enough to shift down into reverse from the control box/ throttle.
But if i shift it on top the motor with the control box cable unhooked, i can shift smooth as butter from N to foward and reverse no problem, but i just cant get reverse to work from the control box!! its really driving me nuts, i purcahsed a new transom cable and the two special bellcrank/cable adjustment set plates but it seems so close that i shouldnt have to remove the drive again to reset that adjustment with the "special tools" and a new transom cable but i got the parts/ tools, because thats the next step...any help would be greatly appriciated and could possibly same me from pulling a drive i just installed 3 days ago!
I guess the main question is, If i can shift it into ever gear no problem from back at the transom cable with the control cable unhooked, does that mean the transom cable and bell crank are ok and i dont need to remove the drive again to realighn those?
