Lou C
- Nov 10, 2002
- 13,970
Hey all-I have a 1988 4.3 OMC Cobra. When I first got it I ran it on the OMC Hi Vis oil as per the OMC book with no leaks. When I winterized it last year the local OMC shop recommended I go to the OMC HPF gear oil. About a month after filling it up (winter time) a leak appeared at the relief hole in the lower unit near the water intake. In the spring I brought it to the shop, they replaced a seal in the lower and filled it with one of the newer Merc gear oils (green) saying this is the best stuff to use. Well one month later, same leak! Shop can't look at it for a couple of weeks. I am wondering if these older units will leak with the newer semi-synthetic oils, maybe I would be better off going back to Hi Vis? Thoughts?
