JJBoatr
Thread starter- Joined
- May 3, 2011
- 144
Tech info...1992 Four Winns, 190 Horizon, OMC Cobra 5.0/HO Ford(502APRAMK), Volvo SX style trim pump.
Bought the boat knowing that the starboard trim cylinder had a leak. Rebuilt both cylinders with genuine BRP seal kits. I thought this would fix the issue but it did not. The manual relief valve is tight, the system is free of air and the fluid is at the proper level. I also haven't found any other leaks. I have a seal kit on order for the valve body as this to me is the only logical next step. However, I have never had this problem and was wondering if anyone on here could share any applicable experience. I have heard that you shouldn't attempt the valve body rebuild because of complexity. If anyone has done this is this a true statement? Hydraulics are not complicated as long as you go slow and don't forget where to put check valve springs etc. I have some experience with rebuilding hydraulic components but it was for a fighter aircraft. So too Summarize:
Q1 - Any tips or pointers for this task?
Q2 - Is there another step in troubleshooting I should take before the valve body rebuild?
Q3 - Is it really as complex as some have said in other places?
All help will be appreciated on. Thank you
Mods...I realize there is another recent post that is similar in nature to mine and my intention is not to duplicate effort on this issue. However, I am further along in the trouble shooting and repair of this malfunction and if this post is effectively answered it will inform the other.
