Re: OMC Cobra gear case seals
Shift shaft seal, water pump seal and gaskets (if gasketed), and driveshaft seal.<br />All of these are easy to replace, compared to the prop shaft seal on most L/U's.<br />I would orser a seal kit and impeller, and replace all those seals, run a pressure test,and pray. It's not really THAT hard, but the tools required are oddball and not cheap.
