omc cobra 5.0 having trouble re-installing stern drive
fourwinnsdook
Re: omc cobra 5.0 having trouble re-installing stern drive
Damnit man!!! Tried to post earlier and got booted... Ok, so yea. i got home yesterday with the new bellow, had it installed in 15min. Another 15Min. and i had the outdrive back on. All this talk about everything being lined up is true, but i can tell by your picture that you are cought up at the same place i was. Buy the new bellow, it's about 70.00 but it's worth every penny. I tried to get that thing on for 2-3 hours the other night, and got it on in 15min. this time.Didn't even have to use any lube or soap. The new bellow opening was much bigger.
Haut Medoc
Rowlex, if what he said does not work, you can borrow my alignment tool just to be sure.....
Sounds like he is on to the cure, though......;)​
rowlex
fourwinns: awesome! I will get one ordered up today, did you need any special tools to put it on?
Haut Medoc: sounds good! Thanks!
fourwinnsdook
Nope, it was a little hard to get to the hose clamp bolts, but nothing a swivel socket and an extension couldn't handle. Turn the boat all the way to the right and take the big plastic nut off of the water hose and pull it through the swivel housing, then turn it to the left and take the hose clamp off of the back of the exhaust bellow, and the snap ring off of the front(secures it to the swivel housing), and pull it off. Then loosen the hose clamp holding the back of the big bellow on (turning the wheel however is easiest to get to the bolt). Then rip it out and repeat in reverse. It's pretty self explanitory once you get going on it.
rowlex
sounds easy enough! thanks for the info, the local store has one in stock for 63$ i just need to get it! :)
rowlex
alright!
The new U-joint bellow fixed the problem wooohooo!! I measured the old one and new one with a caliper, the old one was almost 1/4" smaller then the new one.
I have two more questions:
I put 75w90(i think) gear lube in the outdrive....is that good/recommended/okay?
and is it ok that there is a small amount of in/out play on the prop shaft?
fourwinnsdook
Glad to hear it! I think that's the reccomended lube for the outdrive but i'm not sure. As far as the prop play. i can't remmember ever having one that didn't have some sort of movement. Not much, maybe 1/4 inch at most.
rowlex
sweet! thamks for the info boat ran great all day! mine has at the very most 1/8th inch play just didnt know if it needed to be solid :)
thanks for the help everyone!!!
fourwinnsdook
I'm not really sure how tight they are supposed to be, i just remember as a kid spinning the props on my dads boats and trying to pull them out. There was always play in them, and there is atleast 1/8th in mine. I also took mine out, and after changing that shift cable, it shifts like a new boat. man what a difference.
turbotom
Read all other replies on reinstalling stern drive and I was kind of hesitant to pull it apart and change the boots. But I did it anyway, on reinstalling I had problems that it would not go all the way in, it stopped at 3/4 inch. Pulled it out twice to check for problem and found out that that is normal and all you have to do is lube the housing on the stern drive that fits up against the U joint boot and pins it up against the inner housing forming a tight seal. I drew it in with the 6 nuts and it is fine. I'm an auto mechanic and whenever I'd put a transmission in there was always a problem if it didn't go in all the way easily. I guess boats are different. I just wanted to pass this tip along.
Dakota47
3 Year old post.. :D
Racer42
lol yea i just noticed the 3 year old post I am having the same problem. I am a diesel mec and have never had a problem with something going back to gether like this. I will order the new boot and see if it is my problem thanks for all the post as this in my first boat.
