You can see it here on this outboard. It has that old Johnson cream color, but looks white in the photo. The Johnson outboard is the modified "Black Mamba". The outboard is modified to get the most Hp from the lightest weight. It will put similar hp mudmotors to shame in semi, shallow weedy waters on a 12 ft Jonboat. Most excess weight (so far) has been taken off. It was a 9.9, but has 15 carb. This late model 9.9/15 has a longer stroke and bigger bore than early models. I will rebuild one this winter and have larger bore, better reeds and expect to get 17-18 hp. Cut 10 pounds off the weight from 75 to 65. Fantastic for waterfowl hunting!
