OMC 800 Seal
wildturk
I am looking for a part number for a seal the seal i am looking for is the seal that seats on the bottom of the upper unit where the upper unit meets the lower unit this said seal has a groove in it that is where it would mount to the bottom of the upper. Thanks in advance and yes i have searched for 2 days now with no joy and every exploded view is not showing said seal in the parts.
Howard Sterndrive
Re: OMC 800 Seal
do you mean # 38 on this drawing?
38 0308596 SEAL, Exhaust housing 1 $48.25
^ available at any Evinrude dealer
Re: OMC 800 Seal
I would buy a complete seal kit myself
Howard Sterndrive
Re: OMC 800 Seal
does that seal come in the kit? If it does, then yeah, you're a good part of the way to buying the kit $ wise.
Pretty sure the Sierra kit doesn't include that seal, but the Evinrude (BRP) one might... not sure.
Re: OMC 800 Seal
good question. I bought my last kit in 2005. could not tell you if it had that seal in it or not. Did not buy a Sierra kit though.
wildturk
Re: OMC 800 Seal
Both the upper and lower unit seal kits did not include this seal nor the exhaust seal and spring that fits in the front of the upper " Part numbers 26/27". I had purchased both and now just those 2 seals away from completing a full reseal of my outdrive.
wildturk
Re: OMC 800 Seal
I am about to start this project tomorrow. When installing the impeller back into the new housing does it rotate in CCW or CW can't seem to find out what direction i should rotate it in via the manual i have.
Howard Sterndrive
Re: OMC 800 Seal
as you face the ball gear (#55) of the upper gearbox on the bench, that ball gear normally turns clockwise. I always forget impeller direction but I reference it from that. Just nudge the ball gear clockwise and watch the vertical shaft.
One misconception is that the vanes will flip and correct themselves if you get it wrong. They won't.
wildturk
Re: OMC 800 Seal
Would like that thank all those that lent me a hand at my issues. Boat is going for a water test today. Hope that she floats and performs well for me today.
