93fourwinnshorizon
Thread starter- Joined
- Mar 20, 2009
- 7
I have an 1993 OMC 5.0L EFI 200 HP I/O that is garage kept when not in use. The boat has been trouble free until this perplexing problem.
The boat starts up and runs great and idles well and runs perfectly under load and operates at normal temps. (I don't remember the temp number, needle is in the middle of the guage. Never had overheating issue.)
When the motor is shut off after running at normal operating temps, everything is normal. I'll let it sit for at least 2 minutes and when I start it again while it's warm, the idle will surge until it eventually dies.
The computer is trying to compensate for the surging. Surge will go up to 1700 RPM, it does eventually die. If I start it up and put it into gear, it will run fine until I put it back into neutral. It will then go into the idle surge cycle.
If I let the motor cool for a few hours or overnight, the boat starts up idles perfectly again. If I shut it off and let it sit, and try again, the idle surge cycle continues. Gas is fresh and changed over a few times, tried STP gas treatment too.
I even drained the boat gas tank into the family car. Car ran fine.
I brought it into the shop and did a full tune up, and hooked it up to the computer with no error codes.
I changed out the IAC valve, temp sensor, and water sensor.
Areas of interest this spring are: High and low fuel pumps and the coil.
I plan running again, and cooling each of these to see if that has any effect.
Some blog suggested checking the tightness of the "salt and pepper" EFI connectors, but I don't see how those would be affect by temp. Checking the vaccuum as well. I don't have a clue where these are yet.
If anyone has any other ideas, please offer them up as the shotgun approach is getting expensive.
Thanks.
Thanks.
