OMC 4hp with FNR 6hp leg
labougie
I've only just discovered that there was a 'Deluxe' 4hp with the 6hp FNR leg fitted (this may have been a European-only Belgian-made model, I'm not sure). Can a 6hp FNR leg be retrofitted to the smaller post '95 OMC 4hp powerhead and lower casing? Thanks in advance
nwcove
i do believe the 4 hp deluxe shared the same bottom end with the 4.5, 6, and 7.5 hp for awhile. a bit of research on part numbers should answer your question.
boobie
Go to shop.evinrude.com, look up the motors and start comparing.
