omc 400 outdrive
johnnyph88
Re: omc 400 outdrive
and add an ESA system - switches ESA electronic module and wire it up to the ignition
is the 83 outdrive the same gear ratio? might want to just use the lower and keep the upper you have- that way you avoid possible backwards steering issue too
Where is the ESA system? Where does it hook hook up? Do I need the shifter off the 83 boat?
Howard Sterndrive
it's nowhere
1979 boats didn't have an ESA
1983 boats did - located a half dozen different places on differnt models - mine is bolted to a bracket on the port side manifold
maybe the guy with the 83 outdrive has the rest of the boat - that's the best way to get evrything... piece by piece at a dealer, you'll spend close to a grand putting the ESA system together
diagrams are in the 1983 factory OMC manual
1979 shifter should be fine
Is this 1983 outdrive a 400 series?
johnnyph88
it's nowhere
Yes the one that's on my boat now is a 400 series, i don't think the 400 went to 83 right? and I have the 83 boat I have the hole boat so can you tell me what the system looks like? And thanks for all the help.
Howard Sterndrive
400 was 1978-1985
ESA module is the brown plastic lump on the bracket near the steer cable there:
johnnyph88
400 was 1978-1985
http://i5.photobucket.com/albums/y184/hystat/OMC%20ESA/ESA2-2.jpg[/
Does the ESA ony works with an electronic ignition or will it work with a points ignition too
Howard Sterndrive
factory ESA only works with points. You can get an aftermarket module that works with Electroinic ign
