johnnyph88
- Jun 29, 2011
- 18
Hi I have a 79 boat with the omc 140 hp motor and the omc 400 outdrive and it is stuck in reverse anyone know what it might be? and are these electric shift?
thanks for all the help.
if it is the cable in the outdrive is there something easy i can do to check that?
whatever you do, don't force the cable - they are very expensive
Ok I got a 83 omc outdrive will that bolt up to
My 79 omc 140 motor?
The 83 will be a full mechanical while the 79 is a hydro-mechanical drive. The full mech had a mechanism for retarding the RPMs during shifting that the hydro-mech did not have. The full mech drive is preferred, but I'm not sure what all parts are required to get the electronic shift assist (ESA) working on your older motor.
You need the ESA since the full-mech doesnt have the hydraulic damping on the shift mechanism like the hydro-mech obviously has. Shifting a full mech at full RPM will likely break things.
and add an ESA system - switches ESA electronic module and wire it up to the ignitionSo could I just use the lower unit off the 83 if I have the 83 shift box?
