Hi all posted on here before about a fuel pump but now I?m really worried. Let me give you some details first the motor is an OMC Stern drive 4.3 L V6 GM block. The issue I am having is no fuel to the carburetor so the obvious thing is the fuel pump which as I said I just received and will put on tomorrow, but as I was reading the directions it said if the fuel pump still isn?t drawing enough fuel it is the camshaft.
I know I still haven?t put the new pump on but it?s a real concern considering I?ve called around and have been told no one sells or makes a cam shaft for this motor anymore, I was told its obsolete. I know I could be worrying for no reason but can anyone of you guys give some advice what to do if the new fuel pump doesn?t work?
