OMC 3.0L restart problems
gpcraft
OMC 3.0L with a 2 barrel Holley Carb. Electric fuel pump was installed when mechanical pump broke. Initial start no problem. After running for a few minutes, shut engine for a few minutes, sometimes hard to restart or once restarted and moving it will start to miss and stall. I found that if I take a jumper and use it to activate the pump, to fill the fuel bowl it will work. Where is the fuel in the fuel bowl going? I replaced the anti-siphone valve, fuel line, and rebuilt the carb. If you don't stop the boat you will be fine.
Jono69
Re: OMC 3.0L restart problems
Bad oil pressure switch possibly.
Josh114x
i'm having this problem with my 2.3 omc and i'm getting fuel in my oil also. are you also having this problem?
gpcraft
No I''m not getting fuel in the oil, but I did when I had a mechanical fuel pump. The diaphram ruptured and it was leaking fuel in the oil pan.
