mstahl1171
- Mar 16, 2010
- 209
Here's my problem....I am not getting spark from the coil at all. I have disconnected the grays wires from my coil, installed my spark tester and still nothing. I have 8.5Volts DC to the coil. I have checked continuity from the tower of the coil to the + post and - post. That checks good. Also have a back up coil and that to checks out. Tried the troubleshooting tips from the sticky threads in this forum and still nothing. Also check the ESA module and dip switches and they seem to be working just fine. I also installed new points and condenser plug wires, rotor and distributor cap. I also made sure points and condenser are not grounded or shorted. Also checked all the wiring from the ign switch to the engine harness. I also checked the resistive wire to the coil and that looks good.
Also ran a wire from a good 12V source, disconnected the gray wires installed my spark tester, checked for a good ground and still nothing. I am at a loss. Is there something simple I am missing??
