3car
Thread starter- Joined
- Apr 2, 2006
- 132
long story short, I bought a 2000 17 ' javelin venom with no motor, and I bought an 86 ' evinrude 140
looper that had been assembled from a few different motors. it has a v6 gearcase . the boat is slightly
overpowered , and has a 22 p raker prop . the problem is , the boat wont get on plane , just digs . once it
finally planes out , it only reaches about 51 mph by GPS . tach is not working , so I don' t know rpms.
I read somewhere that the looper v4 engines that got the v6 gearcase actually had lower gearsets in
them. is this true? if so , I may be over propped . from my research, this model boat with 115 's typically
run a 22 p prop to the high 50 ' s, but that is with the smaller lower unit and prop .
I was thinking something was wrong with the motor, but now I' m not sure .
someone also mentioned That I may have too much motor in the water, could that cause the planing problem? I have a manual Jack plate that I am going to install, but I was trying to work a few bugs out first.
