omc 115 power pack or timing base?
Proline20seaDrive115
The motor is a 1990 omc seas drive 115 model#16amrdg Searial # R0858402. With all 4 wires from the power back to the coils conected the motor back fires spuders and dies if it even starts. Now if I take off the top starboard wire from the power pack to the coil the motor now idles fine and will even go in to gear. I moved the coils around to test the idea of a bac coil same problem. Then to test the idea I replace the starboard wire from the power pack to coil. I then took off the port side on same problem would not idle if I could even keep it running. Any ideas if its the timing base or timing or the power pack ? seams like as long as the top starboard wire is conected the motor just wont run.
