OMC 115 hp turbo jet
Hardysplace
Am thinking about the purchase of a 1995 14' Boston Whaler Rage with an OMC 115 hp turbo jet. Any problems I should know about. Read some Whaler history about this engine not being too durable - any comments?
12Footer
Re: OMC 115 hp turbo jet
Welcome to iboats.<br />I've also heard bad things about the motor.<br />It was with the oil injection. But the boat is sweet!! If the price is right, I would get it, run the engine into junk,and repower that awesome huil.<br />JMHO
seahorse5
The boat is a bit heavy, and with the 115 it isn't the fastest around. You will not see 40mph, but the mid to upper 30's.<br /><br />The V4 is bulletproof and with reasonable care lasts well over 1000 hours.<br /><br />The biggest problem with all the sportjets is the running too shallow, or blasting the motor trying to back off a sandbar. The sand and shell sucked up into the motor clogs the cooling passages and overheats the engine.<br /><br />Check yours to see if there is a large plastic filter bowl with screen on the port side to help strain the pebbles from getting into the engine. If not, get one from a dealer. It was an option.
Hardysplace
So let's say I go ahead with the purchase (sea trial is next week) and run the current motor into the ground. What's a feasible replacement and associated costs to include labor?<br />The boat is pretty sweet. I like the hull design and lay out and the price is about $1000 under market retail. The trailer has new tires and bearings, but major rust on the wheel wells. We have a Proline 21 for light offshore, but it's a little too big for Indian River fishing and this boat offers a lot of versatility.
Dhadley
Seahorse5 is right on. 90% of all Turbo Jet failures I have seen were from overheat because the water passages were plugged with sand, mud, dirt ect.<br /><br />Any late model V4 cross flow powerhead can be used as a replacement if needed.<br /><br />Good luck!
newsmyrnan
I own a 95 Boston Whaler Rage, 14 foot, with the 115 OMC TurboJet in it too. I have had extensive problems with overheating, and losing power consequently, and have blown 3 exhaust hoses due to overheating. I am in the process of replacing the water strainer mounted to the side of the engine compartment... Will this take care of my overheating problems? If not, what can I do to take care of this! I want my boat back! If anyone has any ideas, it would greatly appreciated!<br />-brett
