older minkota 35 cutting in and out
adsinclair
i recently was given an old minkota 35 electric trolling motor, which was left on a boat in the weather. A hole was in the top cover sheild which allowed water to run down the shaft and sit in the motor housing. I drained the water and removed most of the rust. But now the motor will cut in and out when running. any ideas ??? thanks
Silvertip
Honorary Supreme Mariner
Re: older minkota 35 cutting in and out
Circuit breaker is tripping. It is either too small or the motor is tight, causing it to draw too much current. spin the prop by hand. If it turns hard the bearings are tight.
