older Johnson 55hp, electrical issues
lpotvin
I have an older Johnson motor which runs well but draws power from my battery and gives it no charge. After about 2-3hrs of running, my battery is dead and I cannot start my motor. I should be able to disconnect the battery once the motor is started and it should stay running. Am I correct in this assumption? And where shoud I start looking for trouble?
Joe Reeves
Re: older Johnson 55hp, electrical issues
Disconnecting the battery when the engine is running will damage the charging system. The usual cause of your problem is a shorted rectifier.
What is the model number of that engine?
tashasdaddy
johnb, he can get plenty of help here. that is the purpose of this forum. again what motor do you have, year, model #. never disconnect a battery when a motor is running.
