I recently purchased an '84 16ft flats boat with a 35 hp Johnson outboard that had not been in the water for some years. I had the motor checked out after having some debris-in-the-fuel problems (and paddling back to the dock). After cleaning the fuel pump the motor was fine, but as a precaution I replaced the fuel tank and hose as the bulb showed some deterioration. Now, I can't get fuel to the motor. By inspection only (this is a guess) the fuel connection at the motor seems too short for the fitting on the new fuel line. Unfortunately, I've discarded the old line. Is there an old/new fitting problem between fuel lines and older motors' connections? If so, what are my options? Can I change the motor's fitting myself? Are parts available? What is the connection at the motor actually called so I can look it up?
Thanks
Duane
Thanks
Duane
