Old teleflex oil pressure gauge
Nivekt
Before I pulled my motor I noticed that my oil pressure gauge would bounce all over the place when the engine was running. I never did any thorough tests, but before I put this motor back together I wanted to put a new sending unit in. The only problem is I cant determine which type of sending unit I need for my old Teleflex gauge. As I understand it, there are three types of sending units I could use. Station, Resistance and Ground. Does anyone know what Teleflex was using back in the late '70's?
The OMC part number is 172127 with other corresponding part numbers being Sierra 18-5899 and Mercury 3857532. Getting the sender is no problem, but I would just like to learn more about what kind of sender it is as everyone out there selling them doesnt specify.
Here are some pictures of the front and back of the gauge:
Thank you for your time.
tazrig
Re: Old teleflex oil pressure gauge
You might want to try Teleflex tech support to be sure on that one:
1-877-663-8396
Nivekt
Thanks.
Silvertip
Honorary Supreme Mariner
It is probably NOT a "station" sender as that implies that it is a dual station unit. It is also not a grounding sender since that would be an ON-OFF type sender for and oil pressure LIGHT. Gauges require a resistance element which is the third type. Current resistance elements are 30-240 ohms (assuming you are in the US).
