Remove the tank empty it out. BE CAREFUL fumes are treacherous.Add some soap and water and a bunch of
nuts (like goes on bolts)Shake it up good drain rinse blow dry or dry in the sun.repeat as required.Coat the inside with some oily fuel mix until you add fuel.
