high'n'dry
Thread starter- Joined
- Jul 10, 2008
- 156
I have about a 1984 Novurania Cancuro 420. It has not been used in years but stored well loosely rolled. It is still a good boat I believe.
How can I remove Armor All etc?
The floorboards are wood and they and the keel have some warping, am considereing covering with 1/8 inch aluminum?
I have cross bar steering but need to build or purchase a seat box for comfort and storage, any thoughts?
I am considering raising the transom 5 inches so I can use a standard shaft 25 Yamaha. It is used in the past with a short shaft (15inch) Merc 25. I want to use a standard shaft 20 inch Merc or Yamaha 25. I would laminate with 3/16 aluminum and wood filler and build a removable transom brace that would tie into the wooden keel spar. The 20 inch shaft engine just seems more--uh---versatile?
The floor boards have popped out some in the past on the sides, any thoughts on how to make the floor system more rigid?
Use, primarily scuba diving and playing around. This is a grey and orange Hypalon boat.
Any thoughts and suggestions on these Cancuros? I wonder if parts are available such as floors etc?
What kinds of trailers and set up are recommended for such a boat?
A few years ago I pulled it out, cleaned it up, worked on it some and put it away, this is the boat.
Thanks.
Thanks.
