old motors
g will
i have evinrude s#10427 m#35525...also lark 3...i think it is a 40hp ... what year is it? it has no spark on 1 or 2
JB
Re: old motors
That's a 1961 40hp engine, George.<br /><br />Fuel mix is 24:1.<br />Spark plugs are Champion J4C gapped at .030"<br /><br />There are 2 magnetos (set points at .020"). If you have no spark on either look for something they share: Kill wire, neutral start switch, flywheel key.<br /><br />Good luck and let us know what you find. :)
CATransplant
Re: old motors
Hi,<br /><br />That could be caused by a number of things. To start with, try disconnecting the two small black wires that come from under the flywheel. One goes to the vacuum cutoff switch, and the other goes to the wiring harness plug. You'll find a knife connector on the second one, but you can just disconnect the one on the vacuum switch.<br /><br />With those two wires disconnected, you've disabled the function that shuts off the ignition. Try the spark check again. If you still have no spark, then you'll have to pull the flywheel and check the coils, points, condenser and the spark plug wires themselves.<br /><br />One other possibility is that the key that holds the flywheel to the crankshaft has sheared. In any case, the next step is to pull the flywheel.<br /><br />If you haven't done this before, you'll want a manual for the job, since there are some tricky little bits to do under there.
