Re: Old Merc 1000 Timing and Link-Sync
Not trying to hijack here but I had a very similar issue to this on my 1000SS that I'm trying to get sorted to replace my blown 1000.
When I first assembled the engine I'd split the flywheel and not put it back together in the correct place. I followed the workshop manual and info from here to get it sort of in the right place. However I think I'm in exactly the same position you are right now.
My problem is I haven't got the original marks on the flywheel to tell me where 0.464" should be. Also I don't just have the timing mark on my flywheel, I also have an alignment mark too.
So what I've done is set the # piston to 0.464", place the flywheel (top part) on and turn it until I can get the alignment mark to point to the exact centre of the top of the distributor, then turn the distributor so it hits it's idle stops and then turn line the pulley up on the top with the alignment mark on the flywheel. Replace belt, tighten etc
I've timed it using a light at it is spot-on 36.5 degrees which is where the manual says it should be.
When I try and crank it over it won't actually start but will occasionally fire, but only for about less than a second.
The carbs, distributor, coil, leads were taken from my previously working engine that blew a water jacket, so I know the're all fine.
I'm stumped
