Old fuel tank connectors
kax2000
What connectors do I need from iboats to use this tank? PICT0071.JPG PICT0074.jpg
sutor623
Re: Old fuel tank connectors
Look like some regular ol Merc connections to me....
ajgraz
Good old fashioned Mercury bayonet connectors. What size (hose I.D.) is your fuel line assembly? That'll let us find some exact parts / part numbers.
You can get OEM/Merc or aftermarket (Sierra, Tempo), that does not mater much...but stick to metal/aluminum, the plastic ones are crap.
BTW, there's some inner parts (a piston-looking thing with a ring-seal, a spring) and a nipple missing from your engine side connector in the pic, do you have those?
kax2000
I need the fuel line/primer bulb assembly also.
I do have the new parts for the engine side connector, its just not assembled.
I am looking at this item from iboats....will it do the job?
"Mercury Fuel Line Assembly, Aluminum Fittings" part # 034388-10LPA.
Assembly uses a low perm certified hose. 3/8" I.D. hose, bayonet style fuel line assembly; cast aluminum fittings. Connects to tank fitting 033419-10 (not included). Replaces OEM No# 32-80188A 2.
Thanks for reply
ajgraz
That fuel line assembly should work for you, 3/8" ID should be fine for any size outboard that would use a 6 gallon can. I have a Moeller low-perm fuel bulb in my fuel line, I am very happy with it (some of the old-stock OEM bulbs I have found break down with ethanol fuels).
Question though: do you intend to install a fuel/water separator? What size motor and type of boat?
kax2000
No boat for it yet.
The motor is ?64 850, on a engine stand.
From #14 of this post.
http://forums.iboats.com/showthread.php?t=518356
ajgraz
Nifty old Merc motor. Have you got a control box for it? If so, post a pic, I may have some spare decals to spice it up.
Personally, I would not buy a pre-made fuel line assembly. Lots of reasons why, I'll touch on some...
Many of the new low-perm fuel line assemblies are using Silverado 2000 or 3000 fuel hose (with the greyish-silver cover). Not only is that stuff ridiculously expensive, many have experienced separation of the inner low-perm liner with that particular hose.
Any pre-made assembly will come in a set length and be assembled with crimp-clamps. Makes customizing lengths, adding in fuel/water separator, replacing primer bulb when needed, etc. more difficult than it needs to be.
Instead I'd get a goodly length of Gates or Shields type B USCG approved fuel line, a Moeller low-perm primer bulb, some Sierra or OEM bayonet connectors, brass hose nipples, stainless hose clamps, and make my own assemblie(s). Likely won't cost you any more than a pre-made, and will be as customizeable as you please.
