Old ford 302 no spark
nola mike
The big orange wire comes fe ground side of battery....the cable is wrong color
Then it's wired wrong. That orange wire should go to the battery positive. The small red wire should be on the battery side of the solenoid (I edited my above post which said starter side) and powers your ignition. Where does your battery positive wire go? There shouldn't be a ground wire on the solenoid.
Jakem
Battery positive goes to left stud on solinoid....that orange wire that is with the other black ones on stud goes to the negative on battery
nola mike
Well, now I'm thoroughly confused. Your first pic of an orange wire with black wires--that's the starter or something else?
1. Orange wire on your solenoid. Where does it go? And is that the only orange wire?
1a. There's a red wire on that terminal. Where does it go? Is it the only red wire in the pic?
2. Middle terminals look OK.
3. Yellow wire on the solenoid. Where does it go?
4. Battery terminal wires. Where does positive go? Negative?
Do you have multiple of the same color wires? Your wiring is not original, so who knows what's going on here...
Jakem
That orange wire goes to the ground stud...it is negative off battery its just the wrong color wire...yellow is start terminal next is ignition
.then starter by itself. Those other red wires on the terminal with orange go to that stud as well....it's definitely not original or color coated
Jakem
The positive terminal goes to far left stud
nola mike
Please answer each of my questions specifically...Your descriptions haven't been clear, and still aren't to me. There is a fat orange wire and fat yellow wire on the solenoid. That far left terminal on the solenoid (when looking at your pic) is not a ground stud. I'm not sure what pic #1 is of, I thought it was the starter. Starter should only have a yellow wire on it.
Scott06
Look at the way this is wired up. https://bzerob.com/library/ford/ford-starter-solenoid.html
this shows the two ways the coil gets power, one in run goes through resistance wire
assuming your solenoid is the same pay attention to grounding of body on solenoid
i susoect you are not taking the power to ignition when key is in start off the i terminal. Also the big ground wire doesn’t go to the solenoid. I think the way you wired it you are effectively crossing terminals. I suspect that goes from solenoid to starter positive terminal
did the solenoid you bought come with wiring digram ? Post that if you can snap a pic
Jakem
It's all wired up and running..thank you all
Jakem
Lol well I'm not really sure for 100%. I rechecked all wiring and connections...re set points and it fired up
Jakem
My thoughts as well....I messed with it for a fair bit of time for it to just start working seems odd to me
Scott06
Unless there is a LFW, loose effing wire , might check wire from points to negative side of coil for chaffing. Can ground out the points and effectively kill the spark
Jakem
Now as for dwell...what in your opinions should be good
kenny nunez
The most accurate way to set the dwell is with the spark plugs out and the coil wire grounded. Spin the engine and adjust the points to 30*, the points are going to look like they are too close but do not worry about it and leave the feeler gauge in the tool box. Put the plugs in and set the timing, usually 6* advanced should do it. Make sure the engine is idling as slow as possible when setting the timing.
Jakem
The dwell is right at 30 engine idling about 900..1000 rpm...it runs very smooth and no lag when I Crack the throttle
alldodge
Using an accurate Tach, get the idle down below 800, would be good to see 650
with points.....
set dwell first
set timing second
set idle speed third
dwell changes with point wear
timing changes with dwell change
idle speed changes with timing changes
This annual adjustment is the only downside to points type ignition
Jakem
Alright I'm on the ocean right now....boat wont go over 2000 ram and can't get on plane....wth
