Old Evinrude fisherman outboard
Darrell Shelton
i have an old Evinrude fisherman outboard, 6 hp ?, I need a file line that goes from the motor to gas tank? I only had the motor and found a tank that I thought would work but the connectors on the motor and tank are different?? Can I even get needed parts for the motor and make the tank work with the motor??
hardwater fisherman
Both ends of the fuel line use the same connector. And you need the primer bulb as well.
GA_Boater
Welcome aboard.
Got a serial or model number of the motor? Some of the old ones use a pressure tank and the motor pressurizes the tank.
Look on the back of the connector on the motor. How many hoses? Two hoses means you need a pressure tank and fuel hose.
This stuff I've seen looking through threads. Someone knows for sure.
F_R
Honorary Supreme Mariner
Don't be confused by all those pins on the tank outlet. One is just a stud that prevents you from attaching the hose upside down. The two little pins are valves that get pushed in when you attach the hose. As said, the fittings on the hose are the same on both ends, and were used for many years. No problem.
F_R
Welcome aboard.
The pictures show the motor side connector--a 6hp non-pressurized system. Proposed tank is correct.
Darrell Shelton
82rude
After around 1959?all omc motors used the same connections.My 2011 60hp etec connects to my 74 6hp Johnson tank .On post pressurized fuel tanks the only connection that matters is the one that connects to the motor My 20hp Chrysler uses an omc tank and hose with a omc connector replacing the Chrysler one ,merc tank runs omc ,etc .As long as the motor end male and female plugs match you can use any tank and tank connection you desire.
