old 75hp evinrude
PHILR
I have an old engine thjat I am ready to fire up. What oil to fuel ratio do I use?
JB
Re: old 75hp evinrude
Hi, Phil.<br /><br />How old? If it was made before about 1970 use 24:1. If after then use 50:1.<br /><br />If you have doubts about how old, post the model and serial number here and someone will tell you.<br /><br />Red sky at night. . .<br />JB :)
Rod Holder
Hey PHILR,<br />For reference, my 73'65hp Evinrude takes 50:1<br /><br />I'm no expert, but there are alot of guys that know alot of stuff on this site so stay tuned as I'm sure someone will be able to confirm. I would suggest you reply with the year of your OB.<br /><br />Later.............
seahorse5
The first 75 came out in 1960 and it has all roller bearings,no brass bushings, so it can run 50:1. In 1964, OMC had all their motors on 50:1 and said that all bearing motors could run the 2% mixture. Today's TC-W3 oils outclean and outlubricate the old stuff back then.
juice71
I have a 63 johnson 75 hp. It says the mixture is 24 to 1, but you say I can use 50 to 1?
