Re: Old 6 hp evinrude change water pump
shift to reverse, remove the 4 bolts holding the lower, it will slip down about 3/4 inch, you have to disconnect shift linkage in the space between lower and leg. notice the notch in the shift rod, the bolt has to go back thru the notch.
