OK, here's a good one.
Have a BF50 4-storke Honda on a sailboat and bottom carb is not working. If I spray gumout into it motor runs perfect. Have removed and cleaned carb but no effect. May be low speed jet "tube" which is no longer available and notorious for clogging.
While I source this part, fix, or find a whole new carb........... QUESTION:
Motor is pretty useable on 2 of 3 cylinders from idle to 3,000 rpm.
Is there any reason I should not use it this way till end of season?
Only use this to get in/out of slip.
Appreciate opinions. Cheers.
