Re: OK so the over heating continues OMC
Thanx for the input.<br /> I'm not sure if it was freezing that caused the cracks in the manifold I assumed it was, you know how Cast is it could be just as easy been the Overheat caused them. The plug just came out sort of popped out after I had repaired the lower unit, which was leaking at the side covers and the water started to get in the block before the thermostat opened. Is there away to tell about cracks. I.e. if I ran clear hoses would this indicate air or something.<br /> I did a compression check last year all were in the 125-130 range I would think a blown Head gasket would show here. Also would there not be some indication of water in the oil. In mine even though she indicates overheat the oil is still the same color as it was when it went in and no water in it.<br /><br />I think she will be a very good boat when I get this problem sorted out and I will eventually if the RPM is suppose to run in the 4200-4600 range then Im not far off next prop I get will be lower pitch but this shouldnt be a problem since Im not far off the mark.<br /><br />I will keep trying to track it down with help from here. If nothing else I can still use her although not fast she still can get around and if I must pull the engine in the fall and have it checked and re sealed I will leave this to then since. I really do not have the cash for this at this time. But it may come down to it. I just cant get over the symptom of the thing stopping the Over heat when lifted slightly. This just doesnt make any sense. Unless there is some sort of blockage in the lower unit. I really do not want to try it my self. Ball gears are just about shot now. And I was going to replace them over winter since I will need to have the lower unit off to fix all the stripped bolts holes ruined by the ***** who has been working on it before.<br /><br />Thanx again Alex
