Ok, I'm stummped... What do you call these...
Homerr
I'm looking for the little plastic latches that goes on a tip-out window you seen on lots of cars, RV's, etc...<br /><br />You know the kind.. they tip the window out slightly and then lock back into place. <br />They typically mount either at the bottom of the window or side.<br /><br />What is the official name of those? :confused: <br /><br /><br />I can't find them anywhere!<br /><br /><br />Thanks,<br /><br />H.
Boomyal
Re: Ok, I'm stummped... What do you call these...
Knee joint latches?
Dunaruna
Offset latches (sort of like offset gate hinges) come in various offset 'degrees'......I think.<br /><br />Aldo
deofc
Anti-Gravity Grepson Ring
ED21
Master Chief Petty Officer
Window dohickey. :)
CalicoKid
Check in a salvage yard if you need some.
Homerr
That would be my last resort Calico... <br /><br />I'm just curious what they are called.<br />It's not often I get stummped like this!<br /><br />H.
OBJ
Left or Right handed semi-automatic hemulators.<br /><br />Tilt latch? Window Tilt latch?
SpinnerBait_Nut
Down here they are called bungie cords. :D :D :D
Homerr
I've tried all combinations I could think of and come up with nothing.<br /><br />I was hoping someone on here works in an autobody shop (or similar) that could come up with a name.<br /><br />Thanks again,<br /><br />H.
Originally posted by Homerr:<br /> I'm looking for the little plastic latches that goes on a tip-out window you seen on lots of cars, RV's, etc...<br /><br />You know the kind.. they tip the window out slightly and then lock back into place. <br />They typically mount either at the bottom of the window or side.<br /><br />What is the official name of those? :confused: <br /><br /><br />I can't find them anywhere!<br /><br /><br />Thanks,<br /><br />H.
Ok Homerr<br />Figured when no one came up with a name Id just look at my van repair book... Hmmm doest address them... owners manual... same thing.. looked at van.. ACK they slide! :) <br />MrsLink has a 3 door Suzuki and her side windows have a latch that opens them out to the rear. Neither book refers to them at all :confused:
Homerr
Now you know my dilema!<br /><br />They should have asked this question on Jepordy!<br /><br />Alex, I'll take "name that thinga-ma-jig" for $1000.<br /><br /><br />LOL! :) <br /><br />H.
