Engine - 1989 15hp Evinrude (E15RCEC)
Problem - Complaint of hard starting and have to have choke pulled to keep it running.
Compression good
Spark good
R & R carb, trash in the nozzle well jet, as suspected. Cleaned carb and installed OEM kit, replaced idle tube and all gaskets.
Got engine started and set low speed needle, did link & synk, all linkages adjusted properly. Engine idles and accerlates perfectly. Starts before you even pull the cord 1/2 way out, when you don't let it set for any period of time.
Now the problem, engine REFUSES to start if you let it set overnight.
If you use a little brake clean, I know you shouldn't but it's the only way to get it started, it will fire right off and idle perfectly.
You can shut it down and it will restart with ease if you don't let it set.
I have gone through the factory manual and been to Leroys web site, adjusted everything according to the information given. The plastic top of the carb had a crack in it, replaced it with the new style per Leroys website and adjusted the low speed needle for proper idle. Same outcome, will not start if you let it set overnight.
This engine runs fantastic, when you get it started. Once started, you barely have to rotate the flywheel and it fires right off.
I am open for any suggestions or thoughts that anybody has.
This thing is driving me nuts, it is probably something simple that I am overlooking, but can't see it.
Sorry for the long post, just trying to get everything out there.
Thanks in advance for your help.
Compression good
Spark good
