Lou C
- Nov 10, 2002
- 13,831
I was getting my old 88 Cobra ready for the season, and had an odd thing happen. The engine started well from winter storage, then starting doing something it never did before. It would gasp and stumble if I ran it with the shift system in neutral, with the handle pulled out all the way. But when I ran it in gear, it ran OK again. It felt as if the ESA was engaging with the shift system in neutral, which didn't make sense. I checked the ESA switches as per the manual and they worked fine. I had not replaced the points and condenser in a while and I had heard that bad points or condenser can cause ESA related troubles. Changed them both and back to normal......
