oil/water mixing and leaking....
Motherlode
Hello all, new to the site. I have a 1992 Evinrude100xp STLEND. I am the original owner and have countless hours on it! That said, had it out for coho yesterday and upon putting it back on the trailer, I find I have a problem. There is a water/lubricant froth running from the powerhead area down the shaft. It doesnt really have a gasoline/fuel type smell to it. I am guessing it is an exhaust issue?
There seemed to be an excessive amount of oily exhaust that ran out of the exhaust relief holes and prop hub exhaust after I ran it on the muffs at spring start up. Not sure that has anything to do with anything, there has always been some.
here are some pics and thank you for your help.
Bosunsmate
or a bottom head gasket leak.
Get on to it before it corrodes the bearings, that post i linked covers that
emdsapmgr
Likely a powerhead base gasket failure. 321727 is the gasket. Common on the Crossflows, esp the V4 models like yours. You'll have to unbolt the powerhead, lift it about a foot and put a new gasket in between the powerhead and the exhaust adapter. About a 3 hour job normally. Your problem is not cause for imminent failure, it just really messy. Worse, when the engine is running, the exhaust smoke leaks into the engine cowling. That heavy smoke gets re-ingested into the cabs as the engine runs. That's not good and probably the biggest reason to get this fixed quickly.
Motherlode
Hey All, first time poster here. I am the original of a 1992 100xp STLEND. I have countless hours on her. If I had to guess, I would say close to 3000. 30% of the time under power, 70% of the time trolling. So....here is my issue. When I put her one the trailer after coho fishing on Saturday I noticed a tan, frothy mixture running from under the powerhead and down the back of the shaft toward the lower unit. It doesnt really have a smell of fuel and is very oily/sticky/greasy to the touch. I have pulled the plugs and inspected, all are perfectly clean. Compression tested 105-110 on 3 cylinders and 90-95 on a 4th. Not bad I suppose for the useage.
I believe it is an exhaust issue.There has been a leak of some sort for quite a few years in the lower left corner of the exhaust manifold?? cover between the V. It has always been a little stick/oily there. It almost looks like the frothiness may be in this area as well? or may be the origin of what is running down the shaft? What say you?
Here are some pics and thank you for your thoughts.
Motherlode
Thanks for the replies guys. I actually just reposted this, as I was having issues posting this post and did not know it posted. If you have time, please review the latest post with attached pics this time. Thanks!
Motherlode
It is, but with pics. I was having trouble posting the original and wasnt aware it actually posted.
Motherlode
Ok, I have read the other post and:
Originally posted by Lukef View Post
well. i changed the head gasket and im still getting milky sludge on one plug. may need to pull exhaust cover and take a look. you dont think that crack could be leaking water? whats on the back side of that?
My plugs are in perfect condition. I think I will start with exhaust manifold and cover gaskets.Thoughts?
emdsapmgr
Any milkiness on a plug is likely water. Water intrusion comes from three places, usually. 1. Bad head gasket-which you replaced. 2. leaky exhaust manifold cover.
That could be from the cover bolts loosening up, a deteriorated exhaust manifold gasket or even casting porosity in the inner cover itself. 3. water in the vro tank. If you've checked the oil tank by taking a sample from the oil at the bottom of the tank, the next thing would be to remove the exhaust covers for inspection.
Motherlode
Looks to me like inner exhaust manifold gasket failure....
Does anyone have info on torque specs and sequence for the reassembly? Would it be advised to use some thread locking compound?
Thanks for your thoughts guys. This site is awesome!!
