oil tanks
Jeff Bruce
Just took off twin130 yamahas off my boat and rigged with merc. opti-max. my century boat has an oil fill cap on the outside in the back with hose to tanks, one for each yamaha motor, but with my mercury oil tanks i will have to pull tanks out to fill wih oil. Can i use yamaha oil tanks with mercury opti-max 150 twins? thanks Jeff
woody66912
Re: oil tanks
no yam uses a 12 volt pump to pump oil merc uses a pressurized oil system.merc does offer the same style filler neck setup.
