Oil tank wiring for 2001 Johnson 115
zaph1
1.7 gallon Johnson oil tank with brown and black wires coming out. I just finished installing a 2001 Johnson 115HP and am down to hooking up the oil tank and gas tanks. The monitor beeps normal and the "NO OIL" light isn't on. Any idea where these wires connect to?
Spongeboat Basspants w/ old motor
stylesabu
Master Chief Petty Officer
Re: Oil tank wiring for 2001 Johnson 115
oil tank wires are for low oil light at gauge, no oil connects to motor at vro pump
boobie
Look real closely at your mtr and you should find a plug with the same color code where these wires plug into.
zaph1
As soon as it stops raining I'll take a look at the motor for matching wires. However, without splicing, I'm pretty sure there are no unconnected wires or plug receptacles.
zaph1
I found a plug with a brown w/ black stripe and a black wire. It's towards the rear of the motor with the rest of the plugs. Wires coming out of the tank are brown and black. I also found a heavy gauge red wire, but am pretty certain that's not it.
boobie
Plug the brown wires together and see what happens. They should be your low oil warning.
