Oil slick behind 99 evinrude four stroke
Alwayserins1
I took out my pontoon a couple weeks ago, and after in the water I noticed an oil slick forming behind boat. Went out for a quick trip around to see if it continued, it did. After bringing the boat home, and just now getting to look at it, when I started it the no oil light came on. So my question is, where should I start? I'm not familiar with outboards, but I am a general mechanic with cars and trucks. Any help, advice, or items to check would be greatly appreciated.
boobie
Check the oil level in the crankcase. That's what that dip stick is for.
daselbee
Just like on a car, the no oil light is triggered by an oil pressure sender switch...almost the identical part that you would see on a car, too.
oldboat1
sounds like an oil issue, but if seeing a nice shimmering rainbow in the water, might have a gas leak.
Honorary Supreme Mariner
Is it a 9.9 / 15 hp EVINRUDE----- or a 40 / 50 hp model EVIZUKI machine ?
tpenfield
:welcome: . . . to iBoats.
Possibilities are . . .
​prop shaft seal leaking gear oil into the water.
Maybe gear case upper seal leaking, depending on what motor it is . . .
Engine not running properly, so raw gas making its way to the exhaust. . .
​I'm sure that there are a few other possibilities.
Alwayserins1
Thanks for the Great advice there boobie! It is a 70 HP. I know that it is an oil issue. How do you start to disassemble the engine casing for searching for the oil leak? Should I just go to YouTube? I was hoping it was a common problem. I'll look around
boobie
I'd start by getting a factory service manual for it. Not Seloc or Clymer !!
