oil sensor mariner 1995 125hp
ehaj38
I am having a problem with my oil sensor, i have changed the sensor in the tank and the module.it is still beeping,Neeed some help!!!!!!!!!!!!! 0g198581 gen # .alarm is in One second intervals.
achris
More fish than mountain goat
Re: oil sensor mariner 1995 125hp
Hi and welcome to iBoats.
Best information you can give us right now is the serial number of the engine. It will start with 0, have a letter, probably a D or a G, and then have 6 digits.
Without that number we don't know what we are dealing with.
What type of beep? One second intervals, long intervals or continuous sound?
Chris..............
ehaj38
0g198581 gen # .alarm is in One second intervals. thanks
achris
That alarm sound is for low oil in the oil tank. If the level isn't low, then you have a faulty sensor (very common). It requires removing the tank to get the sensor out, as it's in the bottom of the oil tank. You can verify this by disconnecting one of the sensor wires. If the alarm stops, sensor is crook. Sensor it is part # 87-12886A6.
Chris..............
