OIl Pump Failure what to do
klt599
Hello my first post here hope you cna help me on what to do. <br /><br />1996 Mariner 135. 2 stroke, with 130 hours. <br />The other day i was driving the boat as normal and it performed flawlessly. Whn i turned on the engine after shutting it down I it began beeping continuously whilst operating. I was a long way up river so i drove back to the pick up point the engine shut off once by itself. I waited ten minutes then drove at 1500 rpm back the temperature needle did not go above halfway. <br /><br />Is it likely that there is any damage to the engine what is the best course of action should i just replace the oil pump and assume the engine is ok<br /><br />thanks
Tom Glandon
Re: OIl Pump Failure what to do
may not be the oil pump. could be the alarm module, my 40 hourse merc don the same thing so now I just mix the oil and gas at a 50;1 mix.
Trent
Beep Beep Beep or steady tone? Steady is overheat and beep beep beep is oil. Does it beep when the key is just turned on and the engine is not running?
klt599
It was a beep beeep beep <br />it does this when running and when the key is turned with the engine off..
Clams Canino
You are prolly OK - but have the oil system and sending unit tested ASAP.<br /><br />-W
gss036
I am not familiar with your particular engine, but if you have onboard oil tank, check the cap for cracks around the top where the threads end. Mercury caps have a tendancy to pop the top off the oil caps. Could be the float inside is just stuck.
klt599
just checked the manual it says the engine has enough oil to run for 30min after the warning tones. is this true?? any further comments appreciated
dashaway
My 89 Mariner does that every fall, the screen in the external reservior needs to be wiped clean.<br /><br />Hope this helps
