Oil Pressure Switch
cjflanagan
Engine S/N: OC527124<br />Transome S/N: OC700948<br />Drive S/N: OC751904<br />Engine: 350 Magnum<br /><br />Where does the oil pressure switch that goes back to the audio alarm screw into the engine? I'm all set with the oil pressure sender. It's the switch for the buzzer I'm asking about.
Laddies
Banned
Re: Oil Pressure Switch
Most are tied off the same hole as the pressure sender
Don S
Should be located just above the oil filter on the port/aft part of the block.
cjflanagan
Like put a 'y' there with two holes, screw the switch in one and the sender in the other?
cjflanagan
<br />Should be located just above the oil filter on the port/aft part of the block.
I have a remote oil filter, you must be talking about down where the oil filter would have been, just above that?
Don S
Yep, that's the place.
cjflanagan
Thank you sir... By the way on my coil issue from the other night, I have found that I have good power on pin six up to the key switch, but no continuity back from the key switch to Pin 5 Male side.
